The screen resistor is 12 ohms high-should be 680 reads 692 and the other should be 330k and is 343k. Is this far off enough to cause problems?. Both per diagram are well with-in tolerance.That's what is throwing me off. I put new caps in the spots where the Sam's book and diagram said " check these".This does not seem heat related either. The set comes up locked in both vert. and horiz. and stays there, just not wide enough. Could the fly be "off" but not bad?
