Old 07-23-2009, 10:33 AM
ctc17 ctc17 is offline
Thanks for the info.
I started checking out the combo unit. The tuner is ultra dirty. It has this foam pad in the bottom that is decaying and coating everything with oily foam crust. Also the plastic fine tuning gear is cracked and not turning the slugs. (jb weld time on that)
After I get those things fixed Ill check the agc and if.
It appears the crt is very weak too. I need to start checking voltages.
