Television Specialties TV-497 Kit Chassis
The underside of that chassis looks pretty cool. I'm thinking more like late 40s not 50s.
http://cgi.ebay.com/Television-Speci...-/300463591350 Last edited by bandersen; 09-05-2010 at 12:21 AM. |
Wow, that thing has some serious looking chassis components in it. Like the seller suggests, 'military'. Did some stuff that came out of Russia look like that on the underside?
Evolution... |
that's all wire lacing underneath, a required skill in both military and telephone work until the 70s. The wiring and components all scream military.
I wonder if it ever worked?
Holy High Voltage!, it has a Zenith Flyback like the one I need for my 10" Porthole! The whole HV assembly looks like it came from a Zenith, IB3 socket, Doorknob cap and all. If there's a weak link on that set that's it! |
Eric, you read my mind. The most beautiful flying machine you could build might never get off the ground....
It would be interesting to get a gander at that schematic. Presumably the design must have been capable of working in some fashion. Or maybe not. The seller says the builder made "some changes" . . . .
Phil Nelson |
I don't know. That tuner looks original to me.
I think it may be a company upgrade. Looks like a military style set from the late 40's. I suspect it worked. It would have to be re built now. Atleast electrolytics, and, the loose paper caps. I love the wiring. Looks so Dumont! I saw that set yesterday on eaby. Neat set. Wish it was mine. I think it should be saved, and, restored. On your Zenith. Maybe you could talk to the other guy who did a retro in ARF, and, retrofit another flyback to your Zenith. I wouldn't wreck this rare set for that. Neat piece of American history. Is that a 10FP4 alum. pix tube it has? Bill Cahill
"Tubes are those little glass things that light up orange unless there is a short.. Then they light up all pretty colors..." Please join my forum. http://www.tuberadioforum.com/ |
![]() I wouldn't use this set for parts either, and yes, it's an aluminized tube, most likely a 10FP4. With all the Mil Spec parts it might work now, or at least not need much to get it working. It would be hell to troubleshoot I suspect. |
This thing is built like a brick outhouse!
I have some surplus coils like the ones on the sub-chassis. I suspect this company or some of its employees had military contract work at some time. An engineer steeped in mil-std design could have had a hand in this! However the bathtub caps, strap-mount caps and ceramic standoffs could have been procured as surplus as well. They had a rather small-quantity run, it appears. A list price for this would be nice to have. As for the harness, my Heathkit HR-10 had one, as did some other stuff I worked on in my factory days. The Vertical output, flyback, cardboard-cased 'lytics and tuner all scream television. |
Open mouth wide. Insert foot in mouth. Chew on foot. Meal is called Hoof in mouth." Bill Cahill
I don't think they used enough iron in that one transformer...
