![]() I found some time to do an FM alignment and work on the cabinet this weekend. One of the three sections of the tuning knob was broken off when I received the radio. It looked like someone had tried to glue or melt it back together but failed. I went hunting for some glue and found this 2-part epoxy formulated for plastics. It smells, looks and feels different than epoxies I've used before. I figure that's a good sign because those others didn't work so well on plastic. I roughed up the surfaces, mixed the glue and applied a small amount the both surfaces. Although it takes 20 minutes to cure, I only had to hold it together for about a minute for it to hold in place. I let it sit for a couple hours just and it's good as new ![]() Now for a dunk overnight in some cleaner. All the old dirt and gunk fell right off. ![]() The plastic cabinet trim was held on with some metal clips. I was able to remove three of them without trouble, but the fourth post broke off. Good thing I have that glue! I carefully bent back the tabs on the brass bezel and removed it along with the dial glass. The logo was held on with another metal clip and I got it off undamaged. Time for some cleaning. ![]() The brass polished up real nice. I sprayed it with the brass lacquer and will let it cure for a couple days. ![]() That leaves the plastic trim piece. I've buffed it with Novus and will attempt to fill in the recessed lettering with a lacquer stick or some paint. Last edited by bandersen; 12-26-2010 at 07:56 PM. |
