Steve, I would try adjusting the value of the cathode resistor in the horizontal output tube(s), to see if this could result in a bit more width. Check the amplitude and shape of the parabolic waveform before you change the resistor value so you know what waveform is needed to drive the convergence circuit. But I would think there is some margin available for the convergence circuit.
John Folsom |
