Xsistor Newbie
Hi guys
I mostly enjoy working on the tube stuff but a friend gave me a little Motorola transistor radio. It a cute little guy and it almost works. It's got audio and oscillates as you tune it.But won't tune in any stations. Would like to get a copy of the Sam's for. The model is X14R. Looks to be from the early '60's. The Sam's is #509-14. If someone could make a copy that would be great! It's in pretty good shape. case has no cracks or chips but the speaker grill is dented up a bit and there is a bit of rust on the back on the little metal leg. Think I can flatten out the grill and get it looking good again. Tnx for any help Terry |
Lots of times the electrolytics are dried out and need replaced; then it should come back.
Are the germanium it this set replaceable with the modern silicon jobs? Just curious.
Terry |
Be careful when soldering on those old circuit boards, the glue that holds the copper traces will easily give up and let it get loose.
Motorola X14R
Being a xsistor newbie I follow the suggestions of the guys here but didn't fix the set completely. It was making audio when I got it (hiss) Replaced the caps and I still had hiss but no signal. After a close inspection I found that two of the leads from the loop ant had been disconnected. After repairing those leads I was in business.
This set uses the 226 battery which hasn't been make for a number of years. It looks like a C cell but it's 9v and has a snap connector at each end. I changed the connector to use a standard 9v battery but it's a bit of a tight fit and it was causing the bottom of the case to crack a bit. I think it was already cracked just from the weight of the 226 cell and handling of the set. Anyway I wanted the relieve the stress on the plastic case. So I used a pair of vise grips and crushed the new 9v battery so it fits with a little clearance on each side. The battery doesn't seem any worst for the wear, works fine. Not very elegant but does the trick. Terry |
There are ways of getting of making smaller 9V batteries. The folks at batteries plus were going to make a new battery for my 67' Admiral ultrasonic TV remote, but then found a compatible type in stock somewhere.
I know that Batterymaker makes a replacement for the 226 but he uses those little watch style cells. I was thinking that they would have much current. I'm also a bit of an utilitarian in that I don't really care what battery is in there as long as it works well and doesn't cost $20 a pop.
Darn thing plays really well! good and loud and with low distortion. Am very happy with it. Terry ps I found another one it's turquoise. Very sharp looking! |
Started to multiply
Very Nice!!
Buzz
______________________ Buzzsaaw Sunlitedreams.com
