Old 12-11-2011, 09:53 PM
ctc17 ctc17 is offline
You need to have the factory probes for the 415 or forget the results. How is the hump screwed up? I'm sure you checked the detector diode, I have seen the bypass caps go bad and cause really screwy bandpass.
