Hi Curt,
this console looks like that it was sold by the big warehouses in germany like Quelle or Neckermann in the early 60s. It may be that it was made by Körting. It is a bit cheaper made than the big brands like Grundig, Saba or Telefunken, but i think it is not bad. The tweeters are electro static, they are powered by the primary winding of the output transformer via a capacitor. (you see the 3 wire connection to the speakers). If the ELL 80 is bad, you may have a problem, because this tube is expensive and rare, burt you can use instead two EL 95. Have fun with that Console. BR Frank |
