Old 02-29-2012, 11:57 PM
yea but those stick types are hard to find unless you know of a source. I am down to 1 NOS GE CR-1 and a couple salvaged ones. I came up with a unscientific approach to test them. Used a VTVM on a low volt scale and a few 9v batteries in series for 45v and the stick in a circuit to see how much voltage I get thru the stick then reverse the stick and try again. I used the NOS GE and when compared to a known weak rectifier the diff was large. Crude but it is a quick way to compare. Not sure how much difference is ok, so its still a process being worked out.
