Old 05-09-2012, 03:05 PM
miniman82's Avatar
First Light: 1952-2011
Ran up the chassis to check HV last night, got a solid 21kv so it looks like the Corotron is still good. After making a few checks, I discovered that the B++ line was at only 40 VDC. Tracing it back to it's source revealed an open 1600 ohm 15 watt power resistor, replacing it fixed the problem. Then while attempting to pass a luma ladder through the front end, I also noticed that AGC was really unstable. Finally it quite working all together, and there was no signal. Problem again ended up being a bad power resistor feeding the IF and tuner, this time an 1100 ohm 10 watt job. I don't have one of those laying around, so repairs will have to wait till I can ge that resistor replaced. Apparently they used some pretty low quality resistors in this chassis...
Evolution...
