Old 06-16-2012, 04:31 PM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Got it home a couple of hours ago. The seller was kind enough to transport it from Phoenix to Tucson for gas money (Thanks Rob!!). The thing must weigh 400 pounds. It took four of us to load it onto and off of the bed of the pickup truck. The cabinet is oiled oak. The top of the cabinet needs some work, but is quite repairable. The sides and front are pretty good except for a small chunk of wood missing just under the CRT. Checked the CRT, and the date code is 6340, so it's the original Zenith tube. Lots of RCA type cataracts. I originally thought it might be a replacement tube, as the Zeniths typically cataract with a yellow halo. Good emissions on all three guns and good life test. Must have been a "low-hours" set to have good emissions after 49 years.
