I have a 58 Zenith Space Command that uses a 5AU4 instead of the pretty much standard at the time 5U4. I may be wrong, but it seems like the specs were almost identical and I can sub the 5U4 in with no problems. This particular chassis design was used for a number of years and through the run they used both tubes. A power supply/rectifier is a pretty basic and straight forward circuit that you wouldn't think would require much design change.
I seem to recall reading that the 5AU4 was the improved higher current version of the 5U4, and that putting a 5U4 in place of a factory specified 5AU4 can shorten the life of the 5U4(but this could be me mixing things up).
I wish that I could locate a good working chassis to throw in my 58-9 (?) 24" Space Command! Anybody got anything from a part out?
5AU4 = 5V3. A 5U4GB in its place may indeed have a short life and would probably cause the B+ to sag even while it was still "good". Conversely a 5AU4 subbed for a 5U4 type might shorten the life of the power transformer because it draws 3/4 amp more filament current.
tvontheporch.com |
