Old 06-20-2012, 09:01 AM
Zenith26kc20's Avatar
Most maggies had flyback failures because I doubt the factory dipped horizontal current. My T-933 was running around 225 ma when I got it running. I adjusted the efficiency coil and after two hours it still holds at 189 ma. The color circuit is RCA but with a couple of odd compactrons. The weak point on mine is the tuner! It is a turret but very cheaply made. It would not be a good OTA analog as the fine tuning is a bit quirkey!
A friend of mine had a Maggie roundie for years until a large picture fell from the wall behind it and broke the CRT neck. The chassis was the one with the BIG silver HV cage that had the HV rectifier mounted upside down in it.
