Old 07-11-2012, 09:02 PM
Originally Posted by snelson903 View Post
...,clean a spot on the ground rod file/sandpaper and on the panel wire ,....
Be very careful poking around inside a circuit breaker or fuse panel. Not only is there the usual shock hazard, but another serious hazard called "Arc blast". You've seen sparks when a short happens, but most of those had limited small amounts of power behind them. But the feed from the power company to your house has a very large amount of power available to a short circuit. Enough to melt and vaporize say a screwdriver shaft. And you really don't want your face anywhere near that.
