Old 11-24-2012, 09:38 PM
The capacitors won't cost you too much. Justradios.com or radiodaze.com are good choices. Don't worry about the ceramic discs, just the electrolytics and the "paper" caps (probably Sprague Black Beauties in that set). You could power it up with just new filter caps but it wouldn't work right, and a couple of those BB caps could blow up while you are testing it (not as big a deal as it sounds!) Might be good to do it in sections, trying it after each one. That will help you localize any mistakes you might make, and also teach you what each section does.
