you are pretty close to have it working well. check that contrast adj, if it does not very much, then you prob have an open cap in of the cans, the 200uf IIRC.
A quick test will be to tack in a 200uf + to the center of the contrast pot, neg to ground. just use some jumpers for a quick check. the blurryness is a result of the cateract. |
