Old 04-07-2013, 04:28 PM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
Well, got curious and checked voltages on the 6t8 audio detector tube...
pins 1-2 -3 should be minus.5 minus 1.8 and minus .5 respectively.....they check 20 volts pos. at least on those pins with a digital volt meter. with analog the needle moves off the scale to the left even with the neg lead or pos lead to ground......
now I am confused...
