#31
I meant that the insulator would go around the face of the tube, like the Zenith Portholes that have the thick plastic spacer/insulator around the screen to keep the bezel from becoming electrified. You can see one in this picture, it pushes the CRT backwards just about the right amount. |
#32
Sure looks like it has an adjustment for it. (circled in red)
Edit: Guess not, I see in other pictures on the ETF site that the adjustment on top of the yoke would prevent this slotted adjustment from being used. Or is the metal plate under the wing nut also slotted? If so, then the yoke should be slide-able. Last edited by WISCOJIM; 11-09-2013 at 07:26 AM. Reason: new info found |
#33
Bob D. |
