Old 04-29-2014, 05:12 PM
stromberg6's Avatar
Smile
Originally Posted by miniman82 View Post
There was a special cement used to glue the base onto the tube, I don't know if it's made anymore. RACS in France used electronics safe adhesive, similar to silicone just without the corrosives in it. They drilled a small hole, and injected it through the base pin- that's what I would do.
The special silicone sealant without acetic acid probably isn't a product that you can find on the shelf at your local hardware store. Any suggestions as to where we can find it, I have many tubes that could use it, not just CRTs.
Thanks,
Kevin
stromberg6
