Old 06-20-2014, 10:52 AM
nasadowsk's Avatar
Damn does run fast…
It's gonna be a few days, I'm royally tied up at work Also, the horizontal section is acting up so I'll need to check that out, too. Should be easy fix though, most likely a loose wire or such (the set's horizontal was perfect until i moved the chassis, so it's something stupid)
with the 'new' T14 in place, I expect to at least see something color. Also might replace the osc coil cause it's jammed up...
