Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > General Off Topic Forums
Old 07-05-2014, 08:58 AM
Originally Posted by WISCOJIM View Post
No, no, no.
Don't ever take your remotes apart and remove the black layer between the rubber buttons and the circuit board.
That "black stuff" is not dirt, it is the graphite required to make electrical contact. Remove it all, and your remote won't ever work.
Try some of this: http://www.amazon.com/CaiKote-Kit-sw...pad+repair+kit
I've never had to redo the contacts a second time after using this product.
I honestly was thinking about using Slip-plate, applied with a cotton swab.
That is, on one that is beyond help.
If I do try to clean one, I use rubbing alcohol and a cotton swab. I clean the PC board thoroughly, but just touch the coating on the buttons, with the tip of the swab.
