Old 07-19-2015, 06:33 PM
SwizzyMan's Avatar
SwizzyMan SwizzyMan is offline
Restoring an admiral c322
Originally Posted by tvcollector View Post
I would assume that would be why there is problems, each cap in those cans you restuffed needs to have the negative leads connected to ground, as in metal of chassis, unless those cans are isolated... What I would do is connect all neg leads from each cap in each can together soldered, and run a wire soldered to them to a spot on the chassis that already has a cut out where ground leads are already solder too...
That is what I have done the cap leads were not long enough so I soldered some excess capacitor leads to the neg leads and then soldered that wire to a ground tab
Admiral C322C2 Regent (Restoring)
RCA CTC-7 Pensbury (Restored)
RCA CTC-5 Westcott (Restored)
CRA CTC--4 Director 21 (Restoring)
