Old 02-08-2016, 08:17 PM
Hagstar's Avatar
Hagstar Hagstar is offline
Originally Posted by Phil Nelson View Post
Interesting. Can you give more details about your tuner (what was wrong, what you did to improve it)?
Well as received the tuner was vexing- it passed the color bars and dots etc. fine BUT was blind and deaf to actual video. For a week or so I failed to read your article and didn't know about the 16 volt video injection thing- results on-screen were muddy from injecting the standard 8 volts, assumed I needed a brightener. Meanwhile I was in the queue here to join. FINALLY I stopped procrastinating and demounted the tuner this past weekend. I took a thin test tube brush and denatured alcohol to the contacts, let them dry and squirted the contact disks sparingly with DeOxit. I also checked the resistors in there. Quite a bit of work getting the cover back into shape- it had been bent up by folks not wanting to take it off. Thanks to the article I did it the right way and suddenly had way too much signal- I still haven't throttled the Blonder Tongue modulator back enough yet.
Thanks everyone, Old Coot especially. He helped me get hooked on this with my first TV, a Crosley from the 2002 AWA Rochester meet which I still have.
John H.
