We hate them. They stick together a lot and they're thinner than the old bills so often when you're counting them you miss one or two that have stuck together.
Anyways, grounding 18 did indeed add a credit but then the thing went into an alarm mode and indicated the hopper was empty. That does not seem to of ever been something installed in this. I'm not sure why it would be complaining unless someone meddled with the dip switches. ![]() The pinout seems to indicate the hopper switch is pin 22 on the underside. Grounding that doesn't seem to solve the problem. That hopper diagram lists two different voltages so I'm a bit confused on what's going on here. Edited: Shorting pin 8 however to ground works fine. I guess I might stick with that.
