21EP4B sub for 21YP4
Hi all
I have a Philco with a weak 21YP4 CRT. I also have a NOS 21EP4B rebuild. Will the 21EP4B sub for the 21YP4? The bulbs sure look the same. Thanks, Ed
Well.............Rats
![]() Thanks for the reply Ed |
I've got a spare PM focus unit off of a large neck Philco CRT, and I've put tubes with different face curves in other tubes mounts successfully. It could work...The edges of the mask won't fit the screen in as visually pleasing a manner as the original though...
If the original ain't watchable with a brightener, may as well try the swap....
You're not thinking of the 21AEP4, are you? (That would be a sub for a 21Y, and saves you the bother of aligning the ion trap).
