Originally Posted by dieseljeep
IIRC, it's not used as anything but a surge limiter. It depends on where in the circuit it is used.
Never have worked on one, I only seen one close up at Nick's place.
I just remembered I have the Riders vol 13 coverage on CD rom. Thanks Jim Menning!
I appears to me, that it's a voltage divider for the IF strip and the field neutralizing circuit. I don't have a schematic for the CTC2B. This info is for the 15" set.
Two twenty watt resisters should fit inside the can.
