Old 03-06-2017, 07:03 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Did you replace the high voltage caps with tubulars? When I did my TS-18 chassis I used ceramic discs and they did not work well in the vertical. I would check every resistor and cap in the vertical oscillator and output circuits. Also check for wiring errors. Despite being careful, it does happen. These chassis perform well when restored.
