Originally Posted by andy
It's a rectangular metal box on the board behind the display. Replace all the electrolytics near it. The IC protector is a common part that should still be available from parts suppliers. It's just a fast acting fuse.
I'm not completely sure if this is what you need, but it looks like it probably is (I don't see the IC protector in there).
http://www.ebay.com/itm/NEW-HITACHI-...-/141802554517
The main problem with these VCRs were the poor quality belts they used. Better rubber doesn't turn to goo like that. I didn't care for the belt driven capstan because it only allowed for 3x visual search speed instead of the normal 7x. This is probably one of the last top loading VCRs made. Most RCA/Hitachi VCRs had been front loading for a few years by the time the L line was made.
Alright thanks, that will be a help. How hard is it to take this part out and put it back in? I'm wondering because I tried replacing a Convergence STK chip in an old Rear-Projection TV once and that was a pain in the butt, ended up ruining the circuit traces on the board because the soldering iron slipped several times when I was trying to remove the old STK Chip from the board which I had to do it one at a time.
Speaking of STK Chips I noticed that this VCR uses an STK chip for the power supply, not sure if its for a voltage regulator or what, but that was the first time I had seen an STK Chip in that position before on a VCR.
I believe this is a 2-Head VCR which might explain why they used so many belts, but I'm not sure.
