Old 06-21-2017, 04:13 PM
DavGoodlin's Avatar
Motorola Minion
FWIW - I replaced the standard Philco chevron pattern on my 501X console, which uses the model 16 chassis. I got it from Antique Radio Supply but not sure if anyone makes that pattern yet. Radiodaze has some parts like chassis and tuning condenser grommets IIRC.
No Philco is restored until those cap blocks are done. My super-fast method: "nip" the internal cap wires from above, remove the 1/4 inch screws, spin the bottom upward without disconnecting anything if possible, heat and push with a small rod thru the middle top terminal rivet, the cap will pop right out so you can put the new one in. beware some of these cap blocks also contain resistors.
This radio is one precision unit, will sound amazing but nothing short of a full recapping is needed. I have had the 501 for almost 30 years and it worked on original caps initially. I sent my 501x's 12" speaker to Sound Remedy for a quality re-cone job.
-Dave G
