Originally Posted by SwizzyMan
Now on to the color for now. Everything seems to be fine except for colors with magenta. As you can see the magenta bar fades off into red which I attribute to bad phasing in the G-Y(?) channel. I just am not sure how I would fix it (Phasing adjustment?).
it really would help to put a scope on the R-Y, G-Y, and B-Y outputs to see which ones are smeary. It may be the B-Y amp. If all are smeary, it may be a chroma alignment or even IF alignment problem. How is it affected by fine tuning?
