You check it at the cathode of the hoz output.
Break the connection, put mA meter in series. You also need a cap across the meter IIRC a .01 but check the manual. Also check the G-1 voltage. If its less negative than spec its usually a resistor in the horz osc or one of the tubes. 73 Zeno ![]() LFOD ! |
