Old 08-18-2018, 09:59 PM
Originally Posted by bluenorm View Post
During visual inspection there was nothing burn under the chassis. Power diodes checked OK
open to any suggestion that could help me out
Did you check each diode both forward and reverse? If using a digital ohmmeter, you should disconnect one end of each diode for a reliable test.
As a side note, an analog meter can test each diode for short/no short without disconnecting anything. Gawd, I would never think of being without at least a cheap analog meter with an RX1 scale for situations such as this.
