Old 11-07-2018, 08:40 PM
Robert Grant's Avatar
Robert Grant Robert Grant is offline
Indoor antennas are rarely suitable for reception of digital terrestrial television. This is due to the fact that the digital signal has a high data rate, and any reflections from buildings, walls, appliances or even people (especially if they are in motion) will interfere with the desired signal. If you set gets a corrupted stream, you will get no picture or sound (in analog TV, your picture could be a mess of ghosting, picture rolling, snow, or all of the above, but you could manipulate your antenna to improve reception).
With digital, you're working blind until you happen to get a signal to lock.
If your residence has aluminum, brick, or stucco siding (the equivalent of steel because a metal mesh holds the stucco in place), your indoor antenna will need to be in the attic (but not a metal roof) or in a window facing your local transmitters (which are often NOT in the city of license). You can use a distribution amplifier to run cables through the basement and back through the ceiling to all the other sets.
It goes without saying, use an outdoor antenna if you can.
