Old 08-29-2019, 09:40 AM
trinescope trinescope is offline
I did get the transformer working, at least for about a half hour before I heard the sound of insulation breakdown. I did at least get to see the results of the IF and chroma bandpass alignment I had performed. Much better detail and color quality than before. Back to the drawing board on that transformer, though. I was trying to do the convergence procedure when the transformer went bad on me, so I didn't get the chance to take any pictures.
I need to find something for winding layer insulation that has a bit of grip to it so the windings don't move around so much. Kapton is good for insulating the inside and outside of the windings as well as between primary and secondary, but is too slick to hold the individual layers. Double sided tape is too thick for this purpose as it will result in a coil which will not fit in the core window. I used fiberglass resin in a glass jar under vacuum for impregnating, it seemed to work but is too thick, also expensive since I had to throw away over 90% of the material afterwards. I could try something like good old Minwax polyurethane and hope it will cure all the way through. At least the unused portion can be saved. This has been an interesting, although a bit costly learning experience. I would like to try doing some audio output transformers later on down the road with what I have learned so far.
Erich Loepke
