Old 11-07-2019, 05:32 PM
Boobtubeman's Avatar
<---WANTED: Motorola 17P6
6A7 tube substitutes?
Popped the top off my 6A7 tube and may not be able to mend it
I have some digit tubes 77,78 ,58, etc.
Just wondering if i have a sub in my pile before i go online and order a new one..
Thanks..
SR
Old 11-07-2019, 06:51 PM
7"estatdef 7"estatdef is offline
Better order one. None of your others will fit into the socket. 6a7 /2a7 are odd balls. Electrically they are the same as a 6a8 but they are octals.
GL
Terry
Old 11-07-2019, 10:32 PM
What i meant was 6C6 will sub a 77 and a 6D6 will sub a 78, is there a # that will sub a 6A7??
SR
Old 11-08-2019, 10:03 AM
SR
The 6A7 is a pentagrid converter tube and the only one that I know of, with the same characteristics in a UX7 base. More modern counterparts are the 6A8, 6SA7, even 6BE6.
I'm surprised that the prices went that high.
Old 11-08-2019, 07:40 PM
GL
Terry
IIRC, the 6A7 was the first pentagrid converter tube and not really an oddball tube. They were being used from around late 1934 to the late 30's.
Some firms adopted the octal based tubes earlier. Many still used the UX bases much later, Philco especially.
The pentagrid tube replaced the use of the separate oscillator and mixer tube or the autodyne converter setup.
Old 11-08-2019, 08:34 PM
DavGoodlin's Avatar
Motorola Minion
Steve, In case this link is dead where I saw them on ebay and I have three myself. https://www.ebay.com/i/262346461158?...SABEgLPgPD_BwE
-Dave G
Old 11-08-2019, 09:51 PM
Popped the top off my 6A7 tube and may not be able to mend it.
Is the wire broke off completely flush with the glass?
Old 11-09-2019, 09:59 AM
For that price, he should buy two! They should only charge one shipping charge?
Those 6AF6G's look pretty interesting. I wonder if they could sub the 6E5 just by changing the socket?
Old 11-09-2019, 06:23 PM
DavGoodlin's Avatar
Motorola Minion
A good 6E5 was in an RCA victor console's RC-1192 tuner, but I needed it for a Crosley 1127 (1937 Dynatrol 11) console radio I was restoring and found a way to make a 1629 eye tube work in the RCA.
I had to change tube sockets, then swapped a 6BE6 for the 12BE6, and moved some series heater wiring. Probably cant do this in too many radios, but this one's wacky design made it a no-brainer, since I have several 1629s and few 6U5/6G5 and 6E5s sub for those.
-Dave G
Old 11-09-2019, 07:06 PM
Yep, it broke flush with the glass, i had enough to test with and the tube is marginal, so i bit the bullet and bought a NOS one off the bay..
While im inside this radio, is there a good sub for a .25MFD cap?
SR
Old 11-09-2019, 08:43 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
A new .25MFD cap
Old 11-09-2019, 09:00 PM
DavGoodlin's Avatar
Motorola Minion
.25 costs a bit more than the .22 And...that may not matter if its a bypass cap and not in an RC network
-Dave G
Old 11-10-2019, 01:22 AM
In parallel heater sets you can make a 1629 socket adapter with a voltage doubler on the heater to convert 6.3VAC to 12.6VDC...Heater don't care if it has AC or DC as long as it has enough of it...I've done this more than once.
Old 11-10-2019, 01:23 AM
Originally Posted by mr_rye89 View Post
A new .25MFD cap
If you have a .22 and .03 you can wire them in parallel. Some restorers get pissy when they see it but it works fine.
Old 11-10-2019, 09:31 AM
dtvmcdonald's Avatar
SR
In just about any radio, any spot ... either a 0.22 or 0.27 uF cap.
In fact, they would be OK in just about any TV, even in a timing circuit.
Normally use a 0.27.
Only in real hi-fi audio filters would it matter.
