#151
![]() how did you find the cross reference? I looked many times and never found anything. ![]() It looked right, so I got it, thanks.
#152
You're welcome. I have an OEM to Meissner cross reference book. Most of the aftermarket coil companies published those. For some reason FADA was not included, so I used the RCA number. Another equivalent is Merit TV-100, which Play Things Of Past shows 3 in stock, but they have a minimum order and no picture of the part.
#153
Those cross-reference manuals are the overlooked gold of TV collector documentation. Nobody seems to be scanning them AFAIK and in a few decades when those with them pass on if nobody picks them up and saves them that info is going to vanish.
#154
First smoke test PASS!
![]() As in caps replaced and slow power up with rect tubes installed, nothing caught fire or exploded, 300v out of diode tubes, nice smell of warm 70 year old resistors. Did not do much else yet, I have a LOT of tube pins and sockets to clean next. :/
#155
voltages are all wrong, no surprise there with the crazy voltage bleeder used.
routing the chassis ground THROUGH the focus coil and adjustment from the source xformer center tap to the voltage bleeder is... weird. they also seem to route main bias through horz and vert centering controls to the bleeder,, strange setup. having dirty tube pins/sockets does not help as this was meant to be loaded.
#156
#157
Well now that I looked it does appear both Sams and Riders voltage references are from chassis ground. I do think the b- dropper string is easier to understand looking at the Sams schematic. B+ center tap is connected through the focus coil and 3 series resistors to ground. Because all b+ current passes through those components it creates a negative voltage across it's path to ground. The closer you get to ground, the less negative the voltage becomes. Hope that makes sense?
#158
right now, all voltages are wrong, which is not surprising, since my tube sockets and pins are very dirty, i need to clean, many would not even light up heaters w/o removing and replacing. the point that shows 300v on the Riders is at 378v with the variac at 70% and the point that says -100v shows -30v. the big resistor in the voltage bleeder is getting very warm, burned my finger. I'm gonna see what happens after i clean the tubes, I'm hoping that after they are clean and the load is more stable, the voltage will be more stable, otherwise, i will have to track down why it is not normal :/
#159
High B+ and low B- would indicate some circuits aren't pulling enough current. As B+ current increases you'll see more voltage dropped across those B- series resistors between the center tap and ground. B- will become more negative and B+ will become less positive. The reason that happens is because as the tubes conduct more they become a greater load on the B+
#160
That's what I thought and since when I pull most of the tubes and see this... https://imgur.com/A0vwGiE I was guessing i need to do a lot of cleaning.
#161
If you are powering up with original caps or you haven't done so yet; check resistance on every section of power supply divider power resistor... They have a tendency to go bad on these.
#162
Did a quick check of the power resistors, in-circuit, but not out. There seems to be a ton of info on how to clean tube pins , but not so clear on how to clean sockets safely. Going to polish the pins till shiny, using cleaner, buffer. Some say to use pipe cleaners on sockets, but I doubt there is one small enough for the 7-8 pin minis. Some say just spray socket with cleaner (deoxit) and stick the tube in and out a few times.
#163
I've never tried it myself, but I hear torch tip cleaners work well.
#164
Some real tobacco pipe cleaners (not the dopey (f)arts'n'crafts ones) have a thinner metal core than a 7 pin tube socket.
My default 7/9-pin socket cleaning method is hose tube base pins with contact cleaner till drips hang off the pins, possibly the socket too if I feel it is necessary, then rapidly insert and remove the tube 3-10 cycles.... that usually does the trick except in sockets corroded badly enough that changing them was basically needed anyway and sockets that no longer grip on all pins.
#165
I just have to wonder WTH was RCA thinking when they came up with this bleeder power design...
By routing main ground (-100) trough the focus coil and the adjustment for it, won't that cause the -18 & -2 to change when you adjust focus? Not to mention reference gnd with respect to the positive bias voltages? It's hurting my head trying to understand what they ment to do...
