#211
Ordinarily those small test CRT's can be supported by only the yoke on it's tower, with maybe some type of non abrasive clamp on the neck to keep it from sliding forward?
#212
i will try to come up with something
#213
My 5" test CRT had this wedge edge clamp on it when I got it. I'm not sure if that came with these new or was somebody's later solution.
#214
but mine is MUCH heavier
#215
I have two similar scopes to the one pictured. The add-alt-chop switch of one does not work properly. Alt and chop work, but add does not. On the other scope I forget but its clt ot chop that does not work. Its the identical switch, my scope lacks the digital top row. Can this be fixed? I've tried to looking inside and did some checking, but can't tell if its switches, relays, or whatever. Does somebody know what to do? |
#216
as far as I know, even with scopes this old, it's done with rudimentary logic functions inside the scope and the switch has little to do with it, other to tell it what mode to go in, even my Tektronix 7934 even though it's from the mid 80s, has very complex logic circuits in it.
#217
that rf signal generator i mentioned will be here wed
![]() now, do I just start with tweaking the replaced coil for the 1st IF, or should I be looking at ALL of them, since it's so old? and it says use "isolated alignment screwdriver" but most if not all these adjustments are done by turning brass turn screws that move the iron cores, are they not already isolated?
#218
I would only adjust what's known to be replaced, then reevaluate and proceed from there.
I'm not so sure that generator is going to serve you justice. I'm not familiar with it's circuitry, but unless you have a frequency counter it's hard to know how accurate something like that is. It would be best to use a plastic blade screwdriver, or in a pinch you can sand a flat blade shape on the end of a wooden dowel. Last edited by Kevin Kuehn; 03-30-2020 at 09:54 PM. |
#219
#220
Ahh, good plan. You could even mark the dial at the specific frequencies you'll need. One thing I've noticed with low cost AM generators is that they often have all kinds of harmonics, especially on the higher frequencies. In fact they often rely on harmonics to produce some those high bands. Sometimes a good counter can even have trouble sorting that all out. |
#221
YES, audio does work!
![]() https://www.youtube.com/watch?v=I-40z8WvsQs the WERRRRRRRR you hear in the background is my server, in which are 3 vantec tornado 80mm fans, that sound like a 747 when they start up! :p
#222
It sounds nice and clear. One could always roll off some high end with a tone control hidden under the chassis, but for my hearing it sounds about right.
#223
that's NOT the speaker that will go with it when done, obviously I just hooked up a tiny 3 inch 16 ohm speaker from an old color TV for test, I still have the 8 inch jensen speaker that was in the set that still seems to be good after 71 years
#224
adjusting the 1st IF coil helped a bit, but I still have a lot of RF noise, the B+ getting to the tuner is very low, 99v where it should be 130v i need to replace resistors in the IF bias chain, cause they put the tuner at the END of that chain :/
#225
https://imgur.com/iju7vXo
umm yeah i would say that is a big problem Brown / Green / Brown is 150 ohms... NOT... :O
