You shouldn't assume. I'm just a step or two above novice. :-P No, I am not shorting the pins. So, I should do this when the board is not installed in the unit and I'm testing? Should I short it when the board is plugged in to the wall? It's just something I'm not familiar with and I apologize for coming across so ignorant. If I'm wrong here, would you mind explaining to me the process of using this shorting pin, and when I would use it? Also, where did you get that diagram? I did not see that in the service manual. I guess I could have missed it though. Also also, thank you for taking time to converse with me about this. I'm just excited about owning this, and really want to get it working. I'll short those pins and then report back what I find.
I have a stupid motovlog. It's really stupid. Please subscribe (if you want). I'm begging. The MotoDork Last edited by cornponious; 05-22-2020 at 01:33 PM. |
