Old 06-27-2020, 09:59 PM
I now have a RF generator that I can have precise control over , freq and amplitude, unfortunately, the tuner cleaner did not come today as hoped, meaning it will be here Monday or later, (USPS is very slow lately ) meaning I won't be able to attempt to do it until Aug, most likely after I have recovered and can lift things again w/o risk of ripping the things they are trying to fix in my shoulder
there is still one thing about the alignment setup I am unsure of.
where as it says Channel 9, in though the aut inputs and gives exact setup for setting RF gain via "contrast " at -3 volts, and what freq to use for each coil trap adjusted, it does NOT mention what amplitude to use, I can select any range from 00.000v to 10.000, so what would be needed to do this?
has anyone done this before and know the right range to use?
screenshot of the PC interface for the RF generator
https://imgur.com/lwu3fZK
