Originally Posted by JohnCT
If you didn't add a B+ dropping resistor or bucking zeners on the diodes, your voltage is going to be high. That's generally not a problem short term as long as you aren't stressing the electrolytics or your HV isn't too high.
John
I didn't add a zener or dropping resistors. If anything the LV supplies are 8-14V lower than the numbers I have in my Rider's. May be due to the rectified voltage coming off the Selenium being a little low. I will probably end up dropping a 1n4007 to sub that out too. Will definitely be using a dropping resistor there.
