The audio recording bias Oscillator is only supposed to run while recording. That osc runs at above audible frequencies to facilitate correctly magnetizing the tape during recording...If you run the record osc during playback it may damage the existing recording. If you can identify the audio playback head (its often clustered with the tracking control track head) you could try injecting low-level audio there and see if it makes it through. Some decks especially mid-80's and older had long multi-pole switches on the PCBs that look like those found in 70's and 80's cassette decks. Those PCB switches have to connect into the mechanism correctly to play properly....Case in point I worked on a sony SL-5800 Beta deck where the bottom PCB had such switches and if the bottom PBC was hinged down into service mode (which I needed to do) the switch on the PCB that switched audio from tuner to tape would not be engaged by the mech and stay in tuner mode (I could manually toggle it). Not familiar with your model so I can't offer much more insight.
