#38
The plan with this damn thing is, pull the chassis, AGAIN, and since most resistors, caps, sockets have been replaced, and re-soldered over and over and the SOB still acts up, taking the thinnest gauge solid core copper wire I can get, (30 awg, 1075 Feet $11! cheap!) starting at the tube socket pins, wrap it around each one, and embed it into to solder tracing, wrapping around each and every component pin sticking through the PCB, until I reach the end of that given circuit trace.
This is no doubt overkill, but I have been over and over this PCB checking parts and touching up solder joints, and the damn thing still acts up and reacts to physical contact, this will make absolutely positively sure there are NO LOOSE connections....
