Good call E M
This set uses a FBT winding so at 15Kc's. They did make brightener / isolation in the day,, just use the right kind. 2 tricks for basket cases. 1) there is almost always a one or two ohm resistor in series with the F. Just jump it out, it will bring the F up to abt 8 V 2) On older sets with an open FBT core you can add one turn to the F in series. This should be done with a scope so you dont go too far. 73 Zeno ![]() LFOD ! |
