Silvertone 113/110.700
Look what followed me home today! 1949-50 I think, built by Air King maybe. 12LP4A picture bulb. Knobs, HV cage, rear panel are all present, 5U4GB isn't lol
General Electric CRT ? I'll bet its still good.
What a sweet set! It was probably worth more as a 5U4
Looking forward to see progress on this one. |
Yep the (GE) CRT is good. I found a burned 4.7k resistor on the damper next to a sketchy looking wax paper capacitor. I may swap those and see if it will come up on dim bulbs. The dang schematic I got is the wrong one, but is similar enough that it took a while for me to figure out. Reading those pf value molded paper domino capacitors is a real pain
Very nice find.
I located in Riders 5-1, as Air King models 12T1, 12T2, and 12C1, chassis 700. Your Silvertone version is way out in Riders 10-1, and they show the exact same schematic as the earlier Air King (drawing number 5958). Seems like the Sears chassis no. 110.700 even corresponds to the Air King chassis 700. It appears they used that same chassis with slight modifications with every CRT size under the sun, including rectangular ones. Oh and you probably know it's basically the same Air King chassis in Sams 121 folder 3. Last edited by Kevin Kuehn; 03-01-2022 at 09:50 PM. |
I couldn't find it in Rider's
There's a burned resistor on pin 3 of the damper (6W4GT) the (wrong) schematic doesn't show any resistor on pin 3.....
https://live.staticflickr.com/65535/...be7ab96d_k.jpg https://live.staticflickr.com/65535/...2c168bef_k.jpg |
Awesome! Thanks! Looks like it’s a 47k resistor that cooked
Brought it up on dim bulbs. sound works, horizontal runs....drew a teensy weensy arc off the HV anode (at the jug), not enough for a raster. I think this set runs in the 10-12KV range, and that should draw a decent arc. The B+ is low I think. I may just go ahead and get new caps
I believe I found the Sam's for your TV in my Sam's Stash.
See Picture Below. |
