Old 07-25-2022, 11:04 PM
1 is good, 2 is a charm, 3 is nuts! :P
http://suzaku.live-evil.org/crazy-color.jpg
Seems that all 3 of these gimmick lights are burned out. :O
Bad design.
NPN switch from the 6.3 fil power through a 1/2 wave rect, lighting up 3 2 volt bulbs through a 6.8 ohm resistor, as long as ALL 3 lamps are OK, all is fine, but if one burns out, then they ALL go because the voltage spikes.
they sell them in packs of 10, not gonna do it, I can get ultra bright yellow LEDs that run at 2-3 volts in packs of 20 cheaper.
