Old 09-20-2022, 01:35 PM
You still have no HV, and therefore no boost, so it's a bit odd for it to be red-plating, as there should be no bias on pin 8.
Try voltage check on each pin of V6, with tube in and out, monitoring voltage as the set is turned on.
