Old 09-23-2022, 09:04 AM
Penthode's Avatar
Penthode Penthode is offline
Originally Posted by kvflyer View Post
I have a Heathkit High Voltage Power Supply, IP-17 which I have totally restored. It has voltage and current meters so it would be easy to do.
I have a working T100 that came up on all original electrolytic capacitors. But I have not turned it on for about 8-10 years though. It was rather easy to get going.
8 to 10 years off, if the capacitors were previously good, I dont think will be a problem. I think it is a problem when it has been off for 40 or more years with a sudden power up..
If you use the DC HV power supply across the B plus line to reform the capacitors, I will be interested in your results.
