Old 10-11-2022, 01:43 PM
ok I thought low esr caps were better I can’t imagine where this pull is coming from what is it in this set that’s going to pull 3 voltages down I did nothing to this chassis to suggest a major mistake and I can bet it’s the horizontal oscillator alone pulling everything down while still having hv even though it’s low.
a lot of reading about the subject.
https://www.avnet.com/wps/portal/aba...ic-capacitors/
Where it comes into play is higher frequency buck converter type power supplies, but in vintage stuff like this, it would really not help much at all at 60hz line inputs.
