#751
I don't know where you got the 135v rating, but forget it.
It's a 3 watt 2700 ohm resistor, and will dissipate 3 watts when the voltage is 90 volts DC. (P = (V^2)/R). So, if the specified wattage rating is 3 watts, the circuit was designed to apply less than 90 volts to that resistor. Of course, a circuit fault might put more voltage across a resistor than intended, and that would have to be fixed, and the resistor would indicate that by overheating and smoking. Edit: resistor voltage ratings are usually for momentary voltage that might cause the resistor to arc over. Typical max voltage rating for discrete resistors might be 200-600 volts, but as you see, for DC, the wattage rating may be exceeded long before the voltage is. AC or pulse current will be different, as r.m.s. current determines the power while the peak voltage determines whether the voltage rating is exceeded. Last edited by old_tv_nut; 10-23-2022 at 05:15 PM. |
#752
#753
Was the original wirewound?
Can you post a link to the mouser page? |
#754
the resistor types I mentioned a few weeks back were 750v type metal film ones.
https://www.mouser.com/ProductDetail...Wwtn4Z2Q%3D%3D perfect for this situation. :O which DID you order?
#755
Well it turns out that I never used that site before so the 6.8 and 8.2 were metal film and the oxide the 2.7 is a wire wound.
#756
All the power resistors were wire wound.
#757
Here’s the 2.7 3 watt wire wound
#758
please post info links of the Mouser parts that were ordered, you should have gotten this info in a confirmation e-mail when the order was placed.
#759
Here’s the resistors I got
#760
The only one in doubt is indeed the wire wond one.
https://www.mouser.com/ProductDetail...0BKWoLFQ%3D%3D https://www.mouser.com/ProductDetail...1SlkNR2g%3D%3D https://www.mouser.com/ProductDetail...Mm2017zw%3D%3D https://www.mouser.com/ProductDetail...FaCwg9Xg%3D%3D The 750v ones I had shown on page 46 were a good match and even cheaper, :/ https://www.mouser.com/ProductDetail...Wwtn4Z2Q%3D%3D As a general rule, I try to get a voltage rating that is 2x above the circuit the resistor is to go in, not that a lower won't work, it's just for better longevity.
#761
So the 2.7 k will work but may not last.
#762
It's not going to immediately explode, throwing fire and sparks all over, it will work, but it will always be a weak point, prone to fail at some point.
#763
I don’t understand what’s going on with this set anymore I put the other 2 resistors in v2 the image is even better but the b+ voltages are dipping again and maybe at this point if the voltages were up where they should be I might have video now. One moment there good the next they drop. I’ll have to change the 2.7k resistors maybe v1 v2 are drawing to much because they are not conducting at full. Who knows.
#764
You guys need to read the datasheet a little more closely and take a step back.
The limiting factor on the resistor is power dissipation. Nothing to do with voltage rating. https://www.mouser.com/datasheet/2/3...20-2758246.pdf If you had 750 volts across a 2.7K resistor, it would be pumping out over 200W! Old TV Nut had it right, you hit the 3W mark at 90 volts so there better be much less than that across the resistor. |
#765
