Projectors
Hello! Im just curious why isn’t there any sections about projectors for home theater or am I just not seeing it?
You could try to be that change here or you could go to a forum more active in modern home theater such as the AVS forums.
Videokarma used to be part of Audiokarma.... Basically audiokarma developed a thriving community of vintage TV collectors and retired TV repairmen, and it got split off back around 07 when it got too big and the tube audio guys got sick of tube TV guys being aghast whenever they parted out some nice restorable tube TV set to build an audio amp... Because of the demographic of conversations was what it was it largely has trended along the same path it started on.
Greetings miketuason,
It is true, AVS forum is a good place for projection television. The best IMPO, is here https://www.flatpanelshd.com/flatforums/app.php/rt FLATPANELSHD. There is spirited discussion on this site on your favored topic on the “Flat Panels and digital format” forum. There are a few of us, including myself that enjoy projection television.
Advent A.K.A. Electrohome show up but no others I remember.
Since they all had either a modded Sylvania or Electrohome chassis tech problems are rare. They were very basic early SS sets easy to fix. A rich mans set. That means only the rich & very poor bought them. I worked on a few newer ones, dont remember the names. These were all out like nothing else & hung on the ceiling & gave a HUGE pix. Modules were upwards of 1 K USD $$$ !!! US built & no holds barred. Real HQ stuff. 73 Zeno ![]() LFOD ! |
Curt Palme has a forum for projection TV, the were real big into the high end CRT projectors some years back. I suppose a few of them might still be upgrading Electrohome Marquees, Sony G90s and the like. Some of those high end CRT projectors will resolve a 1080p picture and look glorious when they do but huge heavy expensive hard to fix/find parts for. I had an Electohome ECP projector that made a great image but ended in flames…..
I just settled for a high end JVC LCoS projector from around 2009 or so….. |
I still have a Sony D50 HTU CRT projector. Hugh footprint and hanging from the ceiling. I keep saying when it dies I'll put it to sleep. Good picture on a 84 inch screen.
My first was a VPH1000 sony from a thrift store. I miss that old guy. Analog convergence and only composite in. Had it a LONG time! |
